Hi again - could I bend your ear one more time? I’ve put a boolean in, and breaks in the loops, but it’s not functioning (button press trigger a lights flash during light fade effect).
// Program for Smart LED tape. Button debounce (working) and responds to a contact closure on pin8
// At power on, LEDS all on, colour solid. 4 pins output different colours
// so one this one program can be used for any roundel.
// Upon contact closure (5V n/o) momentary event, the following happens to all 4 colour pins:
// LEDS all off / all on fast pulse (x2), with a LED chase effect to finish
// Lights all on when this finishes, so roundel colour remains visible.
// 20/08/2020 tested stable, with 110k-Ohm resistor between GND and pin8
// 24/08/2020 tested stable, with 4 extenstions of Cat5 (185M) between 12V PSU & 5V relay and Arduino & LED strip
// 25/08/2020 V3_2: test code removed, leaving only code in use
// 30/09/2020 V5: code replacement with ALL leds on and off now (instead of quick increment)
// Timings adjusted for best responsiveness of flashes
// 02/10/2020 V8: Light_Pulse slowly fades between 50% - 100% brightness in a loop, to add minor animation to the solid ON state
// Added an interval timer, so a number of light pulses happen after an adjustable length of time of solid LEDs on
// 05/10/2020 V9: added a check for if a tag event happens while Light_Pulse is in progress, break out and execute Flash_X
// by S.Arbuckle
#include <FastLED.h>
#define NUM_LEDS 38 //number of LEDs in the roundel strip
#define NUM_STRIPS 3
#define DATA_PIN_R 3
#define DATA_PIN_G 5
#define DATA_PIN_B 6
#define DATA_PIN_P 9
#define NUM_COLORS 3
#define LED_TYPE WS2812B
#define COLOR_ORDER RGB
//define input pins
const int PinIn = 8;
const long interval = 18000; //interval at which to run Light_Pulse
int i = 0;
int j = 0;
int brightness = 1;
int fadeAmount = 2;
int flashes = 1;
int buttonState1 = 0;
int lastButtonState = LOW; //the previous reading from the input pin
bool ButtonBreak = LOW; //variable to monitor for tag event, while Light_Pulse is in progress
unsigned long lastDebounceTime = 0; //the last time the output pin was toggled
unsigned long debounceDelay = 200; //the debounce time; increase if the output flickers
unsigned long previousMillis = 0; //store the last time interval timer was updated
CRGB redLeds [NUM_LEDS];
CRGB greenLeds [NUM_LEDS];
CRGB blueLeds [NUM_LEDS];
CRGB purpleLeds[NUM_LEDS];
void setup() {
// tell FastLED about the LED strip configuration
FastLED.addLeds<LED_TYPE,DATA_PIN_R,COLOR_ORDER>(redLeds, NUM_LEDS);
FastLED.addLeds<LED_TYPE,DATA_PIN_G,COLOR_ORDER>(greenLeds, NUM_LEDS);
FastLED.addLeds<LED_TYPE,DATA_PIN_B,COLOR_ORDER>(blueLeds, NUM_LEDS);
FastLED.addLeds<LED_TYPE,DATA_PIN_P,COLOR_ORDER>(purpleLeds, NUM_LEDS);
pinMode(PinIn,INPUT);
digitalWrite(PinIn,LOW); // set initial trigger state
void loop(){
// read the state of the switch into a local variable:
int reading = digitalRead(PinIn);
unsigned long currentMillis = millis();
if (currentMillis - previousMillis >= interval) {
previousMillis = currentMillis;
Light_Pulse(); //activate Light_Pulse at interval time
Light_Max(); //switch all LEDs on
if (reading != lastButtonState) {
// reset the debouncing timer
lastDebounceTime = millis();
if ((millis() - lastDebounceTime) > debounceDelay) {
// whatever the reading is at, it’s been there for longer than the debounce
// delay, so take it as the actual current state:
if (reading != buttonState1) { // if the button state has changed:
buttonState1 = reading;
buttonState1 = digitalRead(PinIn); // only toggle if the new button state is HIGH
if (buttonState1 == HIGH) {
ButtonBreak = HIGH; //to interrupt Light_Pulse if the button state changes
Flash_X();
// save the reading. Next time through the loop, it’ll be the lastButtonState:
lastButtonState = reading;
void Light_Max(){
fill_solid(redLeds, NUM_LEDS, CRGB::Red);
fill_solid(greenLeds, NUM_LEDS, CRGB::Green);
fill_solid(blueLeds, NUM_LEDS, CRGB::Blue);
fill_solid(purpleLeds, NUM_LEDS,CRGB::Purple);
FastLED.show();
void Light_Pulse(){
//fade count limits how many times Light_Pulse runs
for (int fade_count=0; fade_count <= 5; fade_count++)
// brightness = 1; //Set this so its starts at full brightness
if (ButtonBreak == HIGH){ //to interrupt Light_Pulse if the button state changes
Flash_X();
break;
fadeAmount = -1; //Start from light to dark
for (int fade_loop = 0; fade_loop < 150; fade_loop++){ // 135 * 2 gives it the opportunity to go through 0 to 135 twice
for(i=0; i< NUM_LEDS; i++){
Flash_X();
break;
redLeds[i] = CRGB::Red; //set colours in the array
greenLeds[i] = CRGB::Green;
blueLeds[i] = CRGB::Blue;
purpleLeds[i] = CRGB::Purple;
redLeds[i]. fadeLightBy(brightness); //apply the brightness
greenLeds[i]. fadeLightBy(brightness);
blueLeds[i]. fadeLightBy(brightness);
purpleLeds[i].fadeLightBy(brightness);
FastLED.show();
brightness = brightness + fadeAmount; //raise the brightness value
if (brightness <= 0){ //fade up
fadeAmount = -fadeAmount;
brightness = 0 + fadeAmount;
if (brightness >= 155){ //fade down (not to off)
brightness = 255 + fadeAmount; //0=full brightness, 255=minimum brightness
delay(10); //this setting is the speed of the brighness change
void Flash_X(){
for (j=0; j<=flashes; j++){
FastLED.clear(true); //all LED arrays cleared / off
delay(225); //delay time of transition for OFF to ON for flash sequence
FastLED.show(); //all LED arrays set to full brightness
delay(225); //delay time of transition for ON to OFF for flash sequence
redLeds[i] = CRGB::Black;
greenLeds[i] = CRGB::Black;
blueLeds[i] = CRGB::Black;
purpleLeds[i] = CRGB::Black;
FastLED.show(); //all LED arrays set to increment off pixels
delay(8); //this setting is the speed of pixel movement
ButtonBreak = LOW;
