Hi there
I makeing 5 axis cnc with Arduino mega or rmps 1.4
With grblgru
Now I want to add menually g code but I add menually g code and that’s can’t run
Plz give me advice to how can I’m run my machine with manually added g code
Hi there
With grblgru
To understand the problem I think we’ll need to know more about your system and what you’ve tried so far. Can the machine move at all? If so, how is that happening?
Also, it looks like grblgru has a support forum where maybe someone else has had the same problem? The forum is here: https://www.cnczone.com/forums/uncategorised-cam-discussion/311876-cnc-cam-forum.html
Sorry for the late response, but I just got back from vacation.
Yes, as mcdanlj said, this is a proper place to ask questions about GrblGru. Also suggestions to improve the program or criticism are welcome.
@Hiren
Normally it should be possible to load and start your GCode in the menu under “File / Load GCode”. But you can also use the macro possibility to develop your own GCode. See video below.
If that doesn’t work, please provide us your GCode here.
