@FabCreator@Bonne Wilce
QQ: How much is the Z sensor offzet compared to the nozzle?
(I want to include in my ‘autofocus’ macro a G0 xy command before and after the focus, so I can align the nozzle (and later on perhaps the laserpointer) and then the head moves the correct distances to get the Z-sensor to that spot, and back again!)
So this should do it then:
G91 ;Relative positioning
G0 X11 Y-13.5 ;Move 11mm right and 13.5 mm forward
G28.2Z ;Home Z
G0 X-11 Y13.5 ;Move 11mm left and 13.5 mm backward
G90 ;Absolute positioning
Works! Just tested it! It nicely moved the head so the sensor ended up where the nozzle was, moved up for the Z-homing and moved back…
(So, the rest of the community: feel free to copy this macro for more precise autofocus!)
Yes, indeed. When mine are done!.
At this point, i need to fix the tube with tape, cabling the tube and install the pipo. Than adjusting… So not so far as i wanted yet.
