Everything about the new #PowerCode 3d printer PowerCode by Mecano - Thingiverse
looks like an prusa i3 to me
@jinx_OI If you look closely you will find many differences.
The first is the placement of the heated bed platform, by three points, adjustable by only two screws.
You can see the performance here:
The second is the use of diagonal bars to prevent vibration of the frame and give more rigidity.
The construction is different, the front and rear are metal parts. Other different is that the frame does not need to go with threaded holes.
The X axis is designed to integrate a belt tensioner, this X axis is fully compatible with Prusa I3. The Y axis also has belt tensioner.
