Hi everyone,
Ethernet works very fine with the official firmware.bin on my SmoothieBoard 5XC, but when I’m compiling Smoothieware from sources, it doesn’t works anymore!
I tried to compile using a fresh Debian install, inside a VirtualBox, but the problem is the same (the board don’t even ping).
I’m doing:
./linux-install
./BuildShell
make clean all
make upload
I also tried to compile the version of Nov 30, (when the last firmware.bin has been updated on GitHub):
git checkout aa1f8bc
When sending @net command from Pronterface, everyting seem to be OK, I have the IP address I configured…
I’m using the default config file, I only changed:
network.enable true
network.ip_address 192.168.0.222
network.ip_mask 255.255.255.0 # The ip mask
Any clue?
Thank you
Pierre-Xavier
PS: I will share my VirtualBox image on my Google Drive.
Imported from wikidot
