im not sure how 2 libraries operate in the same folder, i dont know how to select which library i want to use… sooo… i moved the fasted3 library out of my libraries and leaving just the esp8266-fastled library, and i end up with a tonne of errors, all relating to the fastled section;
In file included from /Users/kelvinmead2/Dropbox/Arduino/Projects/esp8266fastled/esp8266fastled.ino:65:0:
/Users/kelvinmead2/Dropbox/Arduino/libraries/FastLED-ESP8266/FastLED.h:12:17: note: #pragma message: FastLED version 3.001.000 #pragma message “FastLED version 3.001.000”
/Users/kelvinmead2/Dropbox/Arduino/Projects/esp8266fastled/esp8266fastled.ino: In function ‘void setup()’:
esp8266fastled:76: error: ‘WS2811’ was not declared in this scope #define LED_TYPE WS2811
(and 10 more pages)
finalising on;
exit status 1
In file included from /Users/kelvinmead2/Dropbox/Arduino/libraries/FastLED3.0/controller.h:4:0,
from /Users/kelvinmead2/Dropbox/Arduino/libraries/FastLED3.0/FastLED.h:27,
/Users/kelvinmead2/Dropbox/Arduino/libraries/FastLED3.0/led_sysdefs.h:38:2: error: #error Arduion versions 1.5.7 and later not yet supported by FastLED for AVR #error Arduion versions 1.5.7 and later not yet supported by FastLED for AVR
Multiple libraries were found for “FastLED.h”
Used: /Users/kelvinmead2/Dropbox/Arduino/libraries/FastLED3.0
Not used: /Users/kelvinmead2/Dropbox/Arduino/libraries/FastLED-ESP8266
exit status 1
Error compiling.
I haven’t used the esp8266-fastled library. I’m using just the latest FastLED lib.
But I loaded http://arduino.esp8266.com/stable/package_esp8266com_index.json with the board manager (for ESP8266WiFi.h)
as described in my sketch.
Multiple libraries were found for “FastLED.h” : Maybe you should clean out your PC Arduino Installation completely and set it up new
Don’t forget the \AppData\Roaming\Arduino 15 folder!
I had to do it today on another PC because I got a strange compiler error with my sketch that is working fine on my home PC.
hey, ok, so after a reinstall of fastled, and a reinstall of the espwifi… i can now compile and almost upload… here’s my new error.
Build options changed, rebuilding all
In file included from /Users/kelvinmead2/Dropbox/Arduino/Projects/sketch_feb23a/sketch_feb23a.ino:45:0:
/Users/kelvinmead2/Dropbox/Arduino/libraries/FastLED-master/FastLED.h:12:2: warning: #warning FastLED version 3.001.001 (Not really a warning, just telling you here.) [-Wcpp] #warning FastLED version 3.001.001 (Not really a warning, just telling you here.)
In file included from /Users/kelvinmead2/Dropbox/Arduino/libraries/FastLED-master/FastLED.h:57:0,
/Users/kelvinmead2/Dropbox/Arduino/libraries/FastLED-master/fastspi.h:108:2: warning: #warning “No hardware SPI pins defined. All SPI access will default to bitbanged output” [-Wcpp] #warning “No hardware SPI pins defined. All SPI access will default to bitbanged output”
/Users/kelvinmead2/Dropbox/Arduino/Projects/sketch_feb23a/sketch_feb23a.ino: In function ‘void loop()’:
sketch_feb23a:134: error: ‘webserver’ was not declared in this scope
webserver();
this may be due to me using an esp8266-01?
@Kelvin_Mead depends on what Arduino you are using. I use 1.6.4. From 1.6.6 the compiler was changed to require functions declared before the loop (or just mention every function that is below the loop with void function1(); etc. As I have hundreds of sketches from other projects I dread to revisit each one of them.
I hope that this will be changed back with 1.6.8. @Robert_Wozniak had the sketch re-arranged for 1.6.7, maybe he can share his code with you.
hi iam having trouble uploading this iam using a wemos D1 mini and get the error ‘webserver’ was not declared in this scope any help would be great new to wifi control thanks
@Juergen_Bruegl Iam using Arduino 1.6.7 and i have installed the http://esp8266.com package and i have ESP8266WiFi.h installed do i just copy all the code and upload it thanks for all your help
@Juergen_Bruegl Hey Gyro Gearloose, put on your thinking cap: If I mention your name in a video that I’m making, would you like to be called Jeurgen Bruegl or Gyro Gearloose?
@Garrett_Durland depends on who the targeted audience is: More official use Juergen Bruegl, for your buddies use Gyro Gearloose; if you don’t know ‘aka’ is an option. Looking forward to the video!
