Hi,
I flashed grbl 1.1f on my Eleksmaker A3 to use it with Laserweb, but whatever command Laserweb sends, grbl answers with “error: 23 - G-code command in block requires an integer value.”
Here’s the output on the Laserweb console:
Connecting to Server @ localhost:8000
Server connected
Machine disconnected
Serial ports detected: [{"comName":"COM4","manufacturer":"wch.cn","pnpId":"USB\\VID_1A86&PID_7523\\5&3A6684B&0&2","locationId":"Port_#0002.Hub_#0002","vendorId":"1A86","productId":"7523"}]
Connecting Machine @ USB,COM4,115200baud
Machine connected
Firmware grbl 1.1f detected
Warning: Gcode out of machine bounds, can lead to running work halt
Set all Axis zero
jog(X,1,800)
jog(X,1,800)
Even worse, after I flahsed the original firmware again (which seems to be grbl 0.9), the original Eleksmaker software (EleksCAM) doesn’t work anymore either! When it tries to move the X or Y axis, I hear a hissing sound from the stepper motors, but they don’t move.
Any help is appriciated
Marco
