I’m seeing several of you with moving printers with no real endstops in sight.
I get that you can set the nozzle pretty much anywhere and say ‘here’s 0,0’ but how do you consistently set Z=0? I hope it’s not manual jogging and eyesight, my vision’s declining!
They are so cheap I don’t see why not to use them. I actually had a print recently that could have used max endstops too. Not sure what happened but it was printing fine then just shot off into the back right corner for no apparent reason. No skipped steps… Just took off into no mans land and made one hell of a racket.
I always start/stop the print at a set Z. Got it in start- and end.gcode. Calibrate the bed once in 4 locations using a dial gauge and print for weeks/months with no problem. Never got around to mounting end stops.
