Having trouble trying to print Sunlu PA (Nylon) on the Centauri Carbon. Has anyone managed to use PA if so would appreciate if you could let me know what settings I should use. I have tried looking it up and using what I have found but the end result the model once printed falls apart in my hand. I am using the Eleegoo Slicer v1.5.0.7 cheers
First question is:
What is the moisture content of the filament?
Second:
Are you printing from a drybox?
Third:
What settings are you having difficulty with?
Lastly, photo showing the current results you are getting?
