Electric components starting to be assembled starting with the heated bed, this one from MakerFarm. Bed smaller than the large work surface for this ScannerStrap, will have to see how it works. If heat does not transfer well to all areas of the glass I will modify adding some kind of heat conducting material underneath.
and what type of worm you use
Worm?
