Dry moly lube spray on stainless…can’t get it to come off with steel wool…lol
WOW!
Sweet!
So has all the black region in the background been lased as well? Or just the word Tracy? Looks very crisp on the writing.
@Yuusuf_Sallahuddin_Y …just the word tracy…this was my first test…the rest is just where I sprayed the whole sheet of stainless.
@Scott_Thorne Cool. I looked up this Moly Lube stuff & it seems that its MoS2 (Molybdenum Disulfide). Is this the active ingredient in the CRC Dry Moly? I can’t find that stuff here, but there are other brands/products that maybe are the same.
@Scott_Thorne Cool, might have to get some & give it a go sometime. Would be interesting to test on cutlery.
I made some tests using the same stuff a while back. Try using acetone or alcohol to clean it after you engrave.
I think what worked well for me was actually isopropyl alcohol and elbow grease. It’s been a bit and I tested a few things. Either one is also great for cleaning before you spray the moly on also and acetone evaporates fast.
What was the power level/speed?
I’ve been trying it on SS & Aluminum, but I find that it isn’t really bonded well – cleaning with a nylon brush removes it if you’re not careful.
I also tried chrome, but I expected that to not work…
