Done with layers
Done with layers
Try using masking tape over the wood before engraving, should cut down on the black smudges
Were printing this one out for the OpenBuilds art wall! Awesome @Ariel_Yahni_UniKpty
You wil havw more examples @Mark_Carew_OpenBuild once the test rig is complete, both laser and CNC milled Aluminum and CNC routed wood.
Denatured alcohol will clean up the smoke stains… give it a light sanding with some 200+ grit sand paper after and the image will pop :slight_smile:
