@HalfNormal
You said: That is a definite sign of a short somewhere. I would look at the simplest start which would be your limit switches. They use the same 5 volts that is used to enable the power supply.
Not exactly but we will give you the win!
Besides no-one should be chopped liver!
I said: if the LED on the LPS is not lit (depending on your supply type) that suggests the 5V is not working or perhaps it is shorted to gnd by the connector.
