does Laserweb on pi not support rastering?
does Laserweb on pi not support rastering? It runs great in vector and trace mode but when I try to raster an image the gcode is empty except for a start and end. Just wondering if it is a memory limitation of the pi or an ID10T proble ;-).
PS: Yes I had a pi lying around and didn’t know what to do with it.
right on target - thanks. beam diameter had two decimal points …5 instead of .5. Your awesome thanks.
done. Any idea how to keep the trace from being offset from the image. When I trace an image the trace is offset to the left instead of directly on top of the pic. Is there a setting that causes this? Thx.
Reason I ask is I want to outline the burned in image after rastering it but the trace is offset. Thx.
looks like another beer your way, thx.
Haven’t tried yet but you’re always right so far. I’ll let you know asap.
jogging it over to line them up worked fine. I’ll try to remove the white spaces around the image and see how that works but I am sure you got it right. thx.
Nice examples. Thx.
