Does ChiliPeppr not handle output from Fusion 360 in generic grbl?
First time I’ve seen this. It doesn’t appear to render correctly in ChiliPeppr. Enlarge the second photo and you can see what I mean. Would it run fine?
Here is the file generated from Fusion. http://pastebin.com/QzC4iSWN
I have the same problem but the cut proceed correctly, be aware about the first G28 Gcode, i have to change this line with a G0 z10 if not the first movement goes to z0 and move y and x to next position.
