Does anyone use chillipeppr to machine anything else than PCB?
Does anyone use chillipeppr to machine anything else than PCB? Things like front panels for project boxes and other similar things. What program do you use to generate the GCode for such operations?
Fusion 360. Provides CAD & CAM for gcode.
Yes, and I use F360 and Cambam.
I will check them out, Thanks. What about flatcam?
Fusion 360 does a ton for free.
I bought Cambam with the machine but moving everything to f360. A steep learning curve but free with integrated CAM that works.
I use Artcam but they discontinued it so looking at Aspire. Fusion360 for 3D art is not so easy compared to tools that allow you to do things like layered text reliefs with other graphics. Check out the Vetric FB group to see if this it more to your liking. I also use GIMP and Inkscape to create height map grey scale and have used other tools but ArtCAM is the easiest for me to do most art projects and signs.
Here is a sample of some of the 2.5D I do for small boxes and ornamental pieces.
Fusion 360 I’ve made lots of things from my wife’s engagement ring to a large set of draws.
i do. fusion 360 as stated above
