Does anyone know which order replicape will home XY axis? Additionally,
Does anyone know which order replicape will home XY axis? Additionally, is there a way to change the order (can’t seem to find an answer in the docs)?
I’m finishing up building a coreXY and have it mechanically built where Y needs to home before X. If not, then X will miss it’s switch and the block will go off of it’s rail. I did this to limit the moving wires on the X carriage. I can change the setup if needed but prefer to keep it.
I have built a hypercube. first it homes x, then y.
Please do note that my left motor is connected to X stepper and my right motor to Y stepper.
@Uday_Kumar_Adusumill That is what I was a bit worried about. I may end up redoing my end stops all together to fix it but was hoping for a different solution as I know other boards have ways to modify the sequence.
I forgot to mention before, but my direction x and direction y are also inverted in local.cfg. But I dont think it really matters for which axis moves first.
Sorry, cannot be of more help. Looked into the config, but cant see how to change the order
Thanks for the help @Uday_Kumar_Adusumill ! I found a different setup that will eliminate the issue. Just waiting for new switches to arrive.
