Does anyone know what the "v9" version of chilipeppr tinyg is for?
Does anyone know what the “v9” version of chilipeppr tinyg is for? I have a due running the latest tiny “g2” firmware. I know this has been referred to in the past as the next version of tinyg (which hardware is at v8 currently)… then again I know there are some actual “v9” boards floating around as pre-release demo type hardware. Perhaps @jlauer can help to clarify? http://chilipeppr.com/tinyg?v9=true
?v9=true switch no longer needed, that was work around for bug in G2 that has disappeared.
Ah, ok, we can probably remove the link from the UI to avoid confusion.
I think I’ll rename it to “Do Not Init TinyG Mode” because I still find it useful when trying out new firmware. What it does is it tells the workspace to not send all the init commands like {jv:1} or the huge {“sr”:{“line”:t,“posx”:t,…}} command when you connect to your board. It is not really needed by the general user at all.
