Does anyone know what the Repetier settings would be for a Mod-T printer. I am finding it really a pain to use the native utility just to unload the filament (it has started to quit as it heats the nozzle), I can’t raise or lower the Z axis, heat the head, adjust infill, add rafts, brim or anything else. The web based print software isn’t all that responsive. Now I know I can use the print utility to load GCode generated by something else, so I am looking at doing that, but need to know any setting ‘gotchas’.
Aaaaaaarrrrrggghhhhh
@Ross_Bagley , I presume you mean ripping out the controller but leaving the stepper in there. I do not see any end stops in this thing either.
I wil have to see how they have that rigged, but yes, I think its time to give up on the damned thing.
@Ross_Bagley incidentally, did your group keep the existing Z axis 'thing ’ or did they replace that as well?
That’s what I needed to know. Now I am debating doing the same surgery on my DaVinci. That thing’s electronics are awful too.
