Does anyone know of any glass manufacturers (preferably borosilicate) that can produce a 2’ x 2’ sheet? Got a big bot in the works.
You could contact them for custom sizes: http://flatglassproducts.howardglass.com/viewitems/flat-glass-products-fabrication/schott-borofloat-glass-2
Shouldn’t be too hard, that isn’t a big bit of glass, or are you just boasting? Standard sheet size for Borosilicate is 33 1/2 x 45 1/4 (from a quick Google).
Yeah, can’t imagine there would be a problem getting a piece that size from anyplace that sells glass…
Alternatively, you can get milled aluminum in almost any size.
Also, aluminum conducts heat much better. And doesn’t shatter.
@Dale_Dunn and the surface can be anything you want from mirror smooth to milled texture. Not quite as easy in glass.
You can get custom borosilicate here for not too much: http://www.cgindustrialglass.com/ Minimum order is $50 but price breaks happen after the first piece.
