Does anyone know how to set up a lead in on laserweb for plasma cutting?
Use an external cad software
any suggestions?
I have used fusion and sketchup but I’m not sure how to do the lead in part
I know vectric can do it on most of there software… Cut2d being the cheapest, and it’s pretty easy if you already are familiar with cad basics
Ok will check them out thanks again
Do they work with arduino grbl
There is a ton of post processors out there for vectric software not sure about grbl I can check tomorrow
Thanks but I don’t have plasma cam, have to figure out how to set up a lead in with laserweb for a plasma cutter
Thanks for explaining but this is still not helpful since it doesn’t have anything to do with helping to solve my problem. I don’t need someone to track the issue I need help, also if someone doesn’t understand something, it’s pretty rude to tell them to “just read it”.
