Does anyone know how to get the LaserDRW plugin installed into Corel Draw 12? I am able to cut/engrave directly from LaserDRW, but this doesn’t do me any good unless I want to create in LaserDRW … which I don’t!
Sorry no as mine is moshidraw.
If you go to the Light Objects forum (http://www.lightobject.info/) they might be able to help you. My understanding is that the plug-in only works with certain versions of Corel Draw. I use Laser Draw all the time right now until I upgrade and then I will have Laser CAD. Laser Draw lets you pull in just about any graphic created in most graphics program. I do work in my CAD program or PhotoShop and export the files as BMP or one of the other files it supports and have zero problems. I will admit that LaserDraw is one royal pain and I wish someone would write plug-ins for other packages.
Have you ran the CorelLaser driver setup ? That is the only way that I could get mine to load. Run CorelLaser\drivers\setup.exe If you can’t find that file on disk. I will upload it to the Laser Engraving and Cutting Facebook group https://www.facebook.com/groups/441613082637047/
Yeah, that was it. I had already installed Corel Laser, but when I opened it before, nothing happened. Turns out, if you already have LaserDRW open, Corel Laser will not open. Once I closed LaserDRW, Corel Laser opened and it had the docked Laser toolbar in the upper right corner. Works pretty well!
Could you please upload CorelLASER.exe somewhere I can get it? The CD in my machine was scratched and I can’t read it.
