Does anyone have a lead on the closed loop belts needed for the Herculien?
Does anyone have a lead on the closed loop belts needed for the Herculien? the only ones I can find are at sdp/si and are out of stock until late june :frowning:
Robotdigg has them.
Which closed loop belts? For X and Y or for Z?
Try https://www.beltingonline.com
Between Motors and Side Drive Rods: http://www.robotdigg.com/product/282/228mm-or-232mm-length,-6mm-width,-Closed-loop,-GT2-belt#
For Z Stage: https://www.adafruit.com/product/1184#
These are the links provided in the HercuLien BOM: https://github.com/eclsnowman/HercuLien/blob/master/BOM/HercuLien_BOMV3.pdf
If you click on the prices in the PDF most will take you to links for the products.
doh, I was working off of the XLS and it doesn’t have links for those items. thanks for the leads :wink:
The XLS does as well, that’s what generated the PDF :wink:
ID10T Error… Lookie, there’s another tab :wink:
