Does anyone have a copy of the spindle mount in DXF they could share with me?
I thought that was a common part, did Brandon make that one?
I can’t find my calipers to measure it for you. If I run into them today I’ll sketch it really quick. I have a spare clamp to measure. It’s 1/2” aluminum which is a pain to cut with the R7. He may have used a mill.
@Colin_Kaminski Thanks, even if you have drawing paper (with squares)and could trace it and email it to me. My problem is the get the accuracy around where it mounts to the mount.
You can download the C-Beam from the openbuilds website. I have a quick .dxf made up. It just copies my cbeam drawing that I made a long time ago. It should be pretty close.
My email is colin s kaminski a gmail dot com. Drop me a line and I’ll bounce the .dxf I have.
