Does anybody know because this says 730mm, will it work in a k40? The seller says it does but k40 tubes are around 700mm. Also does it have the right connectors a either end. Many thanks
I don’t have an answer. but some K40 are fitted with a 35W.
http://www.ebay.co.uk/itm/35W-47mm-x-700mm-CO2-LASER-TUBE-GLASS-TUBE-FOR-LASER-ENGRAVING-MACHINE-/261601557151?
Fwiw mine is 720mm end to end.
should this 730mm work then. Do you think the extra 10mm will make a difference? Thanks everybody
Plenty of room in mine.
