I have a home made Delta printer. I have implemented my own FSR based bed leveling sensors. I can do a 3 point bed leveling scheme that works well. But, I would like to be able before each print to have the probe touch the bed and then create a negative z offset for that touch. So, when the FSR is triggered, the nozzle is at bed height and I need it backed off a bit. I have tried several methods but am not having much luck. What would be the best method to have the bed get probed for height, then set the height in script to back off .1 or .2mm. ?
Currently when I do it manually, after doing calibration and homing, I will use M306 Z0 to set the new Z position. But I would like to automate this.
I am a little confused about G30 with a Z parameter. I see it used on one page for Deltas, but then in other places I see documentation that says NOT to use the Z parameter for G30 with a Delta.
That being said,I have tried that. 0.2 is intended to be the positive offset from the probe to the hot end. However, since my probe IS the hotend, I actually need to back off the other Z direction, thus almost need to use a negative Z value. I have found out that Smoothieware does not seem to accept negative Z values for this.
I’ll give it a try when I get home tonight. I could have sworn that I was trying that last night without luck (it appeared to not like negative values). I could very well be wrong though. I’ll update once I try it out. Thanks.
One quick question comes to mind. Does a homing G28, or any other command eliminate these offsets? If I perform this offset and then store to SD (M500) will it retain this offset?
