Greetings all.
I am brand new to 3D printing, and Smoothieware. I have managed to build up a delta kossel and have all the mechanical stuff setup. Now I am stuck on getting the firmware configured. I could really use some help.
I have my z-probe functional and working as expected (G30). But I cant seem to get any of the leveling/calibration commands to work. I am using a Mini differential IR height sensor V1.2 as the Z-Probe.
Below the output from commands and my config. Any ideas?
G28 Works, as expected
G29 crashes into bed. -Z right into the bed.
G30 Works, and returns expected value (Recv: Z:503.4500)
G31 kinda works, and fails about 1/3rd through with the below message:
Recv: Delta Grid Probe…
Recv: Probe start ht is 78.619995 mm, probe radius is 110.000000 mm, grid size is 9x9
Recv: probe at 0,0 is 0.020004 mm
Recv: DEBUG: X0.0000, Y-110.0000, Z0.6800
Recv: Probe failed to complete, check the initial probe height and/or initial_height settings
G32 crashes into bed
Send: version
Recv: Build version: edge-6a09a62, Build date: May 6 2019 12:53:34, MCU: LPC1768, System Clock: 100MHz
Send: M114
Recv: ok C: X:0.0000 Y:0.0000 Z:504.0000 E:0.0000
Send: M119
Recv: X_max:0 Y_max:0 Z_max:0 pins- (XL)P1.28:0 (YL)P1.26:0 (ZL)P1.24:0 Probe: 0
# NOTE Lines must not exceed 132 characters
# Robot module configurations : general handling of movement G-codes and slicing into moves
arm_solution linear_delta # delta
#Basic Parameters
alpha_steps_per_mm 100 # Steps per mm for alpha stepper
beta_steps_per_mm 100 # Steps per mm for beta stepper
gamma_steps_per_mm 100 # Steps per mm for gamma stepper
extruder.hotend.steps_per_mm 420 # Steps per mm for extruder stepper
arm_length 304.11 # this is the length of an arm from hinge to hinge
arm_radius 178.54 # this is the horizontal distance from hinge to hinge
# when the effector is centered
alpha_max_travel 1000 # Max travel in mm for alpha/X axis when homing
beta_max_travel 1000 # Max travel in mm for beta/Y axis when homing
gamma_max_travel 1000 # Max travel in mm for gamma/Z axis when homing
#alpha_current 1.25 # X stepper motor current
#beta_current 1.25 # Y stepper motor current
#gamma_current 1.25 # Z stepper motor current
#delta_current 1 # E0 stepper motor current
#epsilon_current 1.0 # E1 stepper motor current
# Stepper Pins
alpha_step_pin 2.2 # Pin for alpha stepper step signal
alpha_dir_pin 2.6 # Pin for alpha stepper direction, add '!' to reverse direction
alpha_en_pin 2.1 # Pin for alpha enable pin
beta_step_pin 0.19 # Pin for beta stepper step signal
beta_dir_pin 0.20 # Pin for beta stepper direction, add '!' to reverse direction
beta_en_pin 2.8 # Pin for beta enable pin
gamma_step_pin 0.22 # Pin for gamma stepper step signal
gamma_dir_pin 2.11 # Pin for gamma stepper direction, add '!' to reverse direction
gamma_en_pin 0.21 # Pin for gamma enable pin
extruder.hotend.step_pin 2.13 # Pin for extruder step signal
extruder.hotend.dir_pin 0.11 # Pin for extruder dir signal ( add '!' to reverse direction )
extruder.hotend.en_pin 2.12 # Pin for extruder enable signal
#Key Parameter
default_feed_rate 4000 # Default rate ( mm/minute ) for G1/G2/G3 moves
default_seek_rate 4000 # Default rate ( mm/minute ) for G0 moves
acceleration 3000 # Acceleration in mm/second/second.
junction_deviation 0.05 # Similar to the old "max_jerk", in millimeters,
# see https://github.com/grbl/grbl/blob/master/planner.c#L409
# and https://github.com/grbl/grbl/wiki/Configuring-Grbl-v0.8
# Lower values mean being more careful, higher values means being
# faster and have more jerk
x_axis_max_speed 30000 # mm/min
y_axis_max_speed 30000 # mm/min
z_axis_max_speed 30000 # mm/min
alpha_max_rate 30000.0 # mm/min
beta_max_rate 30000.0 # mm/min
gamma_max_rate 30000.0 # mm/min
#Endstops
endstops_enable true # the endstop module is enabled by default and can be disabled here
alpha_max_endstop 1.28!^ # Pin to read max endstop, uncomment this and comment the above if using max endstops
beta_max_endstop 1.26!^ # Pin to read max endstop, uncomment this and comment the above if using max endstops
gamma_max_endstop 1.24!^ # Pin to read max endstop, uncomment this and comment the above if using max endstops
alpha_limit_enable true # set to true to enable X min and max limit switches
beta_limit_enable true # set to true to enable Y min and max limit switches
gamma_limit_enable true # set to true to enable Z min and max limit switches
delta_homing true # forces all three axis to home a the same time regardless of
# what is specified in G28
alpha_min_endstop nc #
alpha_homing_direction home_to_max # Home up
alpha_max 0 # This gets loaded as the current position after homing when home_to_max is set
alpha_min 0 # this gets loaded after homing when home_to_min is set
beta_min_endstop nc #
beta_homing_direction home_to_max #
beta_max 0 #
beta_min 0 # this gets loaded after homing when home_to_min is set
gamma_min_endstop nc #
gamma_homing_direction home_to_max #
gamma_max 0 # Print Height, gamma_max is set to about 20-30mm shorter than the distance to the bed, otherwise it will crash into the bed at high speed.
gamma_min 0 # this gets loaded after homing when home_to_min is set
alpha_fast_homing_rate_mm_s 100 # homing feedrates in mm/second
beta_fast_homing_rate_mm_s 10 #
gamma_fast_homing_rate_mm_s 100 #
alpha_slow_homing_rate_mm_s 10 #
beta_slow_homing_rate_mm_s 100 #
gamma_slow_homing_rate_mm_s 10
alpha_homing_retract_mm 10 # retract/bounce distance after homing in mm
beta_homing_retract_mm 10 #
gamma_homing_retract_mm 10 #
alpha_trim 0 # software trim for alpha stepper endstop (in mm)
beta_trim 0 # software trim for beta stepper endstop (in mm)
gamma_trim 0 # software trim for gamma stepper endstop (in mm)
# Z-Probe
zprobe.enable true # set to true to enable a zprobe
zprobe.probe_pin 1.29^ # Pin probe is attached to, if NC remove the !
zprobe.slow_feedrate 5 # mm/sec probe feed rate
zprobe.fast_feedrate 50 # move feedrate mm/sec
zprobe.probe_height 10 # how much above bed to start probe
zprobe.max_z 450 # maximum default travel for the probe command, will use gamma_max if not defined
#zprobe.debounce_ms 1 # Debounce the probe pin over this number of millisceconds. Set to 1 or 2 if your probe is too noisy and gives false readings.
#zprobe.dwell_before_probing 0.2 # Dwell time in seconds before probing
leveling-strategy.delta-calibration.enable true # Set to true to enable the delta calibration levelling strategy.
# This uses the probe to figure out the plane's tilt and arm's radius
# in a delta machine
leveling-strategy.delta-calibration.radius 100 # Radius at which to probe the three points
leveling-strategy.delta-calibration.initial_height 0 # The initial height above the bed we stop the initial move down after home
# to find the bed. This should be a height that is enough that the probe
# will not hit the bed and is an offset from zprobe.max_z (can be
# set to 0 if zprobe.max_z takes into account the probe offset)
leveling-strategy.delta-grid.enable true
leveling-strategy.delta-grid.radius 110
leveling-strategy.delta-grid.size 9
leveling-strategy.delta-grid.do_home true
leveling-strategy.delta-grid.initial_height 40
leveling-strategy.delta-grid.probe_offsets 0,0,0 # probe offsets x,y,z (Z should always be 0)
leveling-strategy.delta-grid.save true
#Delta Planning
mm_per_arc_segment 0.5 # Arcs are cut into segments ( lines ), this is the length for
# these segments. Smaller values mean more resolution,
# higher values mean faster computation
delta_segments_per_second 100 # for deltas only same as in Marlin/Delta, set to 0 to disable
# and use mm_per_line_segment
planner_queue_size 32 # DO NOT CHANGE THIS UNLESS YOU KNOW EXACTLY WHAT YOU ARE DOING
microseconds_per_step_pulse 1 # Duration of step pulses to stepper drivers, in microseconds
base_stepping_frequency 100000 # Base frequency for stepping, higher gives smoother movement
acceleration_ticks_per_second 1000 # Number of times per second the speed is updated
#Additions
uart0.baud_rate 115200 # Baud rate for the default hardware ( UART ) serial port
second_usb_serial_enable false # This enables a second usb serial port (to have both pronterface
# and a terminal connected)
laser_module_enable false # Whether to activate the laser module at all. All configuration is
# ignored if false.
#after_suspend_gcode G91_G0Z10E-5F4000_G90_G0X0Y-85
#before_resume_gcode G91_G1E5_G90
#leave_heaters_on_suspend true
# I/O
extruder.hotend.enable true # Whether to activate the extruder module at all. All configuration is ignored if false
extruder.hotend.default_feed_rate 600 # Default rate ( mm/minute ) for moves where only the extruder moves
extruder.hotend.acceleration 500 # Acceleration for the stepper motor, as of 0.6, arbitrary ratio
extruder.hotend.max_speed 50 # mm/s
temperature_control.hotend.enable true # Whether to activate this ( "hotend" ) module at all.
temperature_control.hotend.thermistor_pin 0.24 # Pin for the thermistor to read
temperature_control.hotend.heater_pin 2.7 # Pin that controls the heater, set to nc if a readonly thermistor is being defined
temperature_control.hotend.beta 3950 # Or set the beta value
temperature_control.hotend.set_m_code 104 # M-code to set the temperature for this module
temperature_control.hotend.set_and_wait_m_code 109 # M-code to set-and-wait for this module
temperature_control.hotend.designator T # Designator letter for this module
temperature_control.hotend.p_factor 22.2 # P ( proportional ) factor
temperature_control.hotend.i_factor 1.08 # I ( integral ) factor
temperature_control.hotend.d_factor 114 # D ( derivative ) factor
# Second extruder module configuration example
extruder.hotend2.enable false # Whether to activate the extruder module at all. All configuration is ignored if false
#extruder.hotend2.steps_per_mm 90 # Steps per mm for extruder stepper
#extruder.hotend2.default_feed_rate 600 # Default rate ( mm/minute ) for moves where only the extruder moves
#extruder.hotend2.acceleration 500 # Acceleration for the stepper motor, as of 0.6, arbitrary ratio
#extruder.hotend2.max_speed 50 # mm/s
#temperature_control.hotend2.enable true #
#temperature_control.hotend2.thermistor_pin 0.25 #
#temperature_control.hotend2.heater_pin 2.6 #
#temperature_control.hotend2.thermistor RRRF100K #
#temperature_control.hotend2.set_m_code 104 #
#temperature_control.hotend2.set_and_wait_m_code 109 #
#temperature_control.hotend2.designator T1 #
#Bed
temperature_control.bed.enable true # Whether to activate this ( "hotend" ) module at all.
temperature_control.bed.thermistor_pin 0.23 # Pin for the thermistor to read
temperature_control.bed.heater_pin 2.5 # Pin that controls the heater
temperature_control.bed.thermistor Semitec-104NT4 # See http://smoothieware.org/temperaturecontrol#thermistor
#temperature_control.bed.beta 3974 # Or set the beta value
temperature_control.bed.set_m_code 140 # M-code to set the temperature for this module
temperature_control.bed.set_and_wait_m_code 190 # M-code to set-and-wait for this module
temperature_control.bed.designator B # Designator letter for this module
temperature_control.bed.runaway_heating_timeout 0 # How long it can take to heat up, max is 2040 seconds.
temperature_control.bed.runaway_cooling_timeout 0 # How long it can take to cool down if temp is set lower, max is 2040 seconds
temperature_control.bed.runaway_range 0 # How far from the set temperature it can wander, max setting is 63°C
# Fan
switch.fan.enable true # Enable this module
switch.fan.input_on_command M106 # Command that will turn this switch on
switch.fan.input_off_command M107 # Command that will turn this switch off
switch.fan.output_pin 2.3 # Pin this module controls
switch.fan.output_type pwm # PWM output settable with S parameter in the input_on_comand
switch.fan.max_pwm 255 # Set max pwm for the pin default is 255
# Fan 2 (Hotend)
switch.fan2.enable false #
switch.fan2.input_on_command M906
switch.fan2.input_off_command M907
switch.fan2.output_pin 2.6 #
switch.fan2.output_type pwm # pwm output settable with S parameter in the input_on_comand
switch.fan2.max_pwm 150
# automatically toggle a switch at a specified temperature
# useful to turn on a fan or water pump to cool the hotend
temperatureswitch.hotend.enable true # enable this module
temperatureswitch.hotend.switch fan2 # select which MOSFET to use, must match a switch configuration (fan2 below)
temperatureswitch.hotend.designator T # first character of the temperature control designator to use as the temperature sensor to monitor
temperatureswitch.hotend.threshold_temp 50.0 # temperature to turn on (if rising) or off the switch
temperatureswitch.hotend.heatup_poll 15 # poll heatup at 15 sec intervals
temperatureswitch.hotend.cooldown_poll 60 # poll cooldown at 60 sec intervals
# See http://smoothieware.org/panel
# Please find your panel on the wiki and copy/paste the right configuration here
panel.enable true # ʹÄÜÏÔʾÆÁÉèÖÃ
panel.lcd reprap_discount_glcd #ÏÔʾÆÁÀàÐÍ
panel.spi_channel 0 # SPI channel to use ; GLCD EXP1 Pins 3,5 (MOSI, SCLK)
panel.spi_cs_pin 0.16 # SPI chip select ; GLCD EXP1 Pin 4
panel.encoder_a_pin 3.25!^ # Encoder pin ; GLCD EXP2 Pin 3
panel.encoder_b_pin 3.26!^ # Encoder pin ; GLCD EXP2 Pin 5
panel.click_button_pin 0.28!^ # Click button ; GLCD EXP1 Pin 2
panel.buzz_pin 1.30 # Pin for buzzer ; GLCD EXP1 Pin 1
panel.external_sd true # set to true if there is an extrernal sdcard on the panel
panel.external_sd.spi_channel 0 # set spi channel the sdcard is on
panel.external_sd.spi_cs_pin 1.23 # set spi chip select for the sdcard (or any spare pin)
panel.external_sd.sdcd_pin 1.31!^ # sd detect signal (set to nc if no sdcard detect) (or any spare pin)
panel.menu_offset 1 # Some panels will need 1 here
panel.alpha_jog_feedrate 6000 # X jogging feedrate in mm/min
panel.beta_jog_feedrate 6000 # Y jogging feedrate in mm/min
panel.gamma_jog_feedrate 3000 # Z jogging feedrate in mm/min
panel.hotend_temperature 185 # Temp to set hotend when preheat is selected
panel.bed_temperature 60 # Temp to set bed when preheat is selected
#Network
network.enable false # enable the ethernet network services
network.webserver.enable false # enable the webserver
network.telnet.enable false # enable the telnet server
