Delrin bushings Every once in a while I bump into something that just flat
Delrin bushings
Every once in a while I bump into something that just flat amazes me. Delrin is an AWESOME plastic for machining and is very VERY slippery. I just ran across this how-to for using an ACME leadscrew and making a delrin bushing to mate with it.
I dunno bout you, but the Delrin cut-off bin at our local plastic supplier sells the stuff four about $.35 a lb.
http://bbs.homeshopmachinist.net/threads/43645-Making-Acetal-leadscrew-nuts-the-easy-way
So, does this excite you? It makes me kinda giddy.
For leadscrew nuts this is great. I wonder how it would work as a linear bushing.
I can give it a shot…need to order the ingentis bearings and can order the bushings seperately if delrin doesn’t work out.
Could end up making this thing an upside-down mendel with two acme leadscrews for the Z-axis
