I have a Monport 60W CO2 (Ruida controller), with autofocus and air assist. I use Lightburn for the software side.
I’ve been working on creating some leather stamps from acrylic (1/4"). My designs are pretty simple and geometric, so not high detailed at all. I’m able to get a deep engrave with 3-4 passes, but the issue I’m running into is that the engraved areas are very bumpy and rough, like a topographic map, to the point that it ends up showing up in the leather when I use the stamp.
The best results (but still far from good) have been running a speed of 250mm/s and 50% power, with 5 passes. 2 vertical, 2 horizontal, and 1 at a 45 degree angle. Without the last pass, the stamp would’ve been unusable.
I’ve tried running with and without air assist with no real difference.
Any ideas on troubleshooting this?
