Decided to capture the whole 2 hours it takes me to design a simple pattern, cut, and assemble a tea light candle holder. Other patterns or designs can take longer of course. This was a simple one.
Thanks for sharing your process @Ashley_M_Kirchner_No . I’m curious what it is that you are using for masking the entire sheet of ply?
Thanks for that. I’ve been looking around local hardware stores for something to mask with that is wider than 2" with no luck. Maybe something like that is a better option.
Note on that page that they have different strengths. I use the medium and low tack versions. And you’d have to ask RTape for a local distributor … I get mine through the print shop I used to work at.
@Ashley_M_Kirchner_No Thanks again. I’ll see if they have a local distributor here.
Great video!
