I do a lot of wood turning and typically sweep up the BIG stuff followed by vacuuming. This keeps me from overloading the filter in the shop vac with large chips.
I decided to add a cyclone separator to my system.
This build turned out easy to do and pretty inexpensive using a:
I built one of these several years ago using nothing more than 2 buckets, a 2 and a 5 gallon one. You attach the bottom of the 2 gallon bucket to the inside center of the lid of the 5-gallon one, drill a hole through the lid and the bottom of the 2-gallon bucket for your vacuum to attach to(I used PVC for the connection), and then one hole in the side of the 5 gallon bucket about 2 inches from the top of the bucket, that hole will be for attaching to your CNC or whatever. When I tested it, I used about a pound of sawdust and got less than a teaspoon of it in the vacuum cleaner’s chamber.
Yeah, they’re pretty easy to build. I’m building another out of an old 1950s canister vacuum I found on the side of the road that had its motor burnt out. The wheels make it a lot easier to move around.
I got a cheap chinese cyclone for xmas and 3d modelled / printed various adapters for mate with my shop vac hoses. It does a good job but know I need to make it more mobile.
Moving it around is like poking at cold noodles using another piece of noodle. and the cylone doest work well if the bucket has fallen over.
