Cutting 8 mm accoya
Post:
Hi everyone,
I’m looking for advice on cutting 8 mm Accoya using an Epilog Fusion Pro.
Has anyone here successfully cut Accoya at this thickness? I would really appreciate if you could share:
  • Power / speed / frequency settings
  • Wattage of your machine
  • Number of passes
I’m also wondering:
  • Does Accoya behave differently from regular hardwood or plywood when laser
  • Is flame-up a concern at 8 mm? I will be cutting big quantitys and worry about flames heile cutting.
And finally — would you recommend cutting in one slow pass or multiple lighter passes for best edge quality?
Any tips, warnings, or lessons learned would be greatly appreciated.
Thanks in advance
What kind of source do you have? These can contain a glass, metal tube co2 or a fiber. A fiber won’t work on natural products like wood.
When you mention frequency, it can apply to both metal tube and fiber machines.
:grinning_cat_with_smiling_eyes:
Hi mate,
Accoya is basically a type of pine that has undergone acetylation, so it is different from regular hardwood and plywood. Think it a softer hardwood. When laser cutting, I tried so many times and it just usually overburned. But if you have air assist, flames are not a problem.
I have a Thunder Nova plus 80watts. Here’s my parameters:
  • 90% power
  • 8mm/s
  • frequency: 3khz
  • 2.5” laser head
  • strong air blow
  • 1 pass
I tried some times, this parameters can help cut through, but the edge is dark. If you want clean cut edge, try make the speed 12mm/s, 2 passes. But remember wait for 1-2 mins between 2 passes.
Make some tries to find the best parameters for your machine.
Good day : )
Is minimum and maximum power values set?
If head/layer speed is <= to the start speed set in the Ruida controller, you’ll only get minimum power.
Is this an RF laser, I assume so because you mention a frequency of 3kHz. If I’m understanding you, this is only applicable to a metal tube or RF machine.
“I’m working with a CO₂ laser, currently running at speed 10, power 1000, and frequency 10. The results are generally good, but the cutting performance is inconsistent — sometimes it cuts cleanly, and other times it doesn’t. The air assist is on. Could the instability be related to the moisture or dryness of the wood?”
