I bought this sprayer some time ago to use on cabinets and other wood finishing projects.
It’s the simplest, least expensive sprayer I could find but it had impressive reviews by users. I wanted to start spraying water-born finishes.
I finally got around to testing it and I am impressed.
It features:
- Only one adjustment…
- Uses a standard mason jar…
- Needs only 30-50 psi
- Only $50
- Easy to clean
… and sprays as good as any sprayer I have.
This is a piece of maple veneer plywood sprayed with Minwax water-born poly @30psi. The picture doesn’t do it justice. The surface after two coats had minimal orange peel and good coverage.
