Created a “cases” category on the G+ discussion group
Originally shared by Built-to-Spec
We got our hands on the BeagleBone Black earlier in the week and designed an enclosure for it. The design files are free to download on Thingiverse.
http://www.thingiverse.com/thing:82363
Figures, I had just bought the standard BeagleBone case, guess I should have looked closer Regardless I didn’t need the HDMI, and just had to file out a bit wider for the SD card, but old case worked great. (this is my second one as I also have the original BeagleBone, definitely recommend it!)
Looks very #stealthy , wouldn’t you say, @Matt_Ranostay ?
One tip… if you go with these case do NOT overtighten the bolts or it can break the plastic… still holds together and can’t tell as tabs are inside that snapped. Kit is put well together, ships with the allen wrench, and an extra bolt and nut.
