Controller identification
Hi. Can anyone identify this 3D printer controller ? The only indicative marking is Rev. 2.1 and the MEGA2560 uC.
TIA.
What printer is it out of ?. What ever it is, It’s probably Proprietary.
If it is proprietary, i would expect a logo or brand name and a serial number on the PCB. I don’t expect that on the bottom of the PCB. Maybe underneath the fan or the cables on the right of the fan.
It could be Arduino, Ramps and Polulu on a single custom board but this is not a hobbyist job. The person who engineered this board knew what he was doing electronically, not from a marketing viewpoint when the logo is invisible :slight_smile:
I have no idea what the underlying, unstated purpose is… Building new firmware for it? Using it in a new printer? Replacing it because it died? As in, what purpose drives the question?
If it’s building new firmware, I’d expect it’s RAMPS-compatible and you could just build Marlin and select RAMPS and see whether it works… But if it’s for a 3d printer, honestly I’d just buy any modern board that supports the same functions and use that instead. The Atmel processor just doesn’t have the ability to support modern 3D printing features.
Image search turned up:
Not exactly useful. I think @mcdanlj is right, getting a more modern and properly documented board seems like a good idea.
Never give up hope.. it appears to be the main board from a ā€˜ADIMlab Gantry’ .
Even has a board connection diagram…
The purpose of my enquiry is to see if I can recover it or whether it is actually dead. I do have access to programming interface fut working out which uC ports connect to what would be difficult without info or ideally, the code so that I can flash it. I suspect that someone managed to corrupt it’s flash memory. It seems alive, but won’t talk to a PC.through USB.
Thanks for the responses
I’d start by seeing whether your ICSP can can write an image then; if flash is corrupt, then the bootloader that might otherwise allow re-flashing the primary image over USB might be corrupt too, since it’s part of the flash area.
But it’s not an investment of time I’d make; regardless of how good a board it was in the days when Atmel controllers ruled, I would be looking for a 32-bit controller these days.
Good luck whatever you decide to do!
I did, and my friend does, program virgin chips. i.e. no bootloader, but I acknowledge your advice. The main disadvantage is changing the control panel too.
For new firmware, you can search for ā€œADIMLabā€ here:
Looks like it would be BOARD_HJC2560C_REV2
If you find that it’s not just mostly dead, but all dead, then there’s a good chance that you can still use the same console — though you might need to make up a new cable.
I may have been remiss.
Thanks for the info.
The board is alive, scrolling through menus but not talking to the PC. Should be a simple fix if I can find, again, the schematic. I did download it once, but it seems to have vanished into the aether.
