Connection between mosfet and heat bed and ramps1.4
my heatbed is silicion 450 watt
and power supply 360 watt
so i should buying another powersupply above 500 watt for heat bed
You definitely need a larger power supply than the bed will draw. How much larger depends on what else you are powering.
If you want to use a separate power supply for the bed, you will need a separate MOSFET board, I believe; I don’t think that the ramps v1.4 has a separate bed power supply.
Are you running 12V or 24V?
So long as the bed MOSFET is a conventional N-channel type it will be ok so long as both supplies have their 0V lines connected to the board 0V (-) rail.
The +V for the bed should go directly to the bed +ve line, not to the control board. The bed -ve line then goes to the mosfet bed- connector as normal.
Oh, that’s a good point. Connect positive direct from the power supply to the bed, and use the MOSFET to switch the negative to shared 0V / GND.
