Hi all.
I have a problem. I have a laser ingraver, with arduino uno and cnc shield ver.3
I want to connect a laser modul, but the laser only have 2 core, black and red ( yes and 2 to the fan )
I meen i have to connect the laser direct on Z- or Z+, bur it not work
Offcause I have enabled the laser
Z+ and Z- are the z axis pins. I believe you need to use the spin enable pin D12 on the shield. Also set $32=1 to set the arduino grbl in laser mode. The other question is if the laser module is just a laser diode or a laser power supply with a laser diode build in… if it is just a laser diode then you need a current source applicable to the laser diode. E.g. something that put out exact e.g. 1.6V with lots of current. Good luck!
Laser modules with only two wires doesn’t have a TTL/PWM signal input. Instead they just have power wires for the driver/diode. You need to provide power (mostly 12V from the provided power supply) to these wires, which is not available at the CNC Shield. This means you need additional electronics (MOSFET) to switch the 12V power for the laser with the spindle enable signal output from the CNC Shield.
Hint: If you use the spindle enable output, you will not be able to adjust the laser power. It will allways use maximum power! You would need to use spindle PWM output to be able to change the laser power, but a two wire module is not made for PWM modulation and will not work well with PWM modulated power.
A laser diode driver is basically a constant current power supply. Drivers with PWM input have a MOSFET at the output of the driver to switch the laser diode. I expect this to be faster than if the whole regulator has to power up/down with PWM frequency.
My first laser diode module was a two wire module and it kind of worked with PWM, but the result was much better when I replaced the driver with a TTL/PWM one.
