Hi all,
I’ve had the smoothieboard laying on the shelve for a few years. Just got around to playing whit it and installed it in a cheap China CNC mill that (prior to fitting the smoothieboard would accept movement only via a native LPT1 port)
I’ve pretty much solved everything from the information on smoothieware.org, and / or googeling around for information. But the behavior I’m experiencing now boggles me. This is probably a minor but at the moment I cannot get my head around it:
G0 X500 will result in a movement of 50mm, instead of what I suspect 500mm. This (division by a factor 10) seems to go for all parameters given.
My Setup:
- Board: Smoothieboard v1 3x,
- Firmware: I could not find a version number, but installed the latest “firmware-cnc-latest.bin” 2 days ago,
- My configuration > (sorry Im not allowed to post links) pastebin.com / FWFyLM2T
- Prob. not relevant but I send the Gcodes via Pronterface running on Windows 10
Not sure if I left something relevant out, please let me know if I did.
[edit]
It seems that the same behavior applies to the values in my configuration file.
Imported from wikidot
