Hello, I have a problem with my config file. I’m using de latest firmaware.bin from GitHub repository,
The problem is that when I turn on the machine, the commands to move de the three axis respond well, they move de carriage wher I indicate, then, when I sen the homming command, the machine goes to homming position with no problem, but after that, the only movement that the machine accepts It’s homming position again, and no other command, I mean, I can’t move de carriage anywhere with the commands from my TFT screen and only works the homming position command… any Idea?
To add more mistery to this issue, if I move to homming position each axys individually, then I can still move the carriage where ever I want, but, if I hit the homming position command for all three axys at once, then, I’m only able to move to home position all the three axys again, but can not move anywhere…
This is the config for the endstop module that I’m using…can you see any issue there?
################################################################################################################################# # Endstops. See http://smoothieware.org/endstops endstops_enable true # The endstop module is enabled by default and can be disabled here corexy_homing true # Set to true if homing on a hbot or corexy alpha_min_endstop 1.24^! # Pin to read min endstop, add a ! to invert if endstop is NO connected to ground #alpha_max_endstop 1.25^ # Pin to read max endstop, uncomment this and comment the above if using max endstops alpha_homing_direction home_to_min # Or set to home_to_max and set alpha_max and uncomment the alpha_max_endstop alpha_min 0 # This gets loaded as the current position after homing when home_to_min is set #alpha_max 300 # This gets loaded as the current position after homing when home_to_max is set beta_min_endstop 1.26^! # Pin to read min endstop, add a ! to invert if endstop is NO connected to ground #beta_max_endstop 1.27^ # Pin to read max endstop, uncomment this and comment the above if using max endstops beta_homing_direction home_to_min # Or set to home_to_max and set alpha_max and uncomment the alpha_max_endstop beta_min 0 # This gets loaded as the current position after homing when home_to_min is set #beta_max 300 # This gets loaded as the current position after homing when home_to_max is set gamma_min_endstop 1.29^! # Pin to read min endstop, add a ! to invert if endstop is NO connected to ground #gamma_max_endstop 1.29^ # Pin to read max endstop, uncomment this and comment the above if using max endstops gamma_homing_direction home_to_min # Or set to home_to_max and set alpha_max and uncomment the alpha_max_endstop gamma_min 3 # This gets loaded as the current position after homing when home_to_min is set #gamma_max 400 # This gets loaded as the current position after homing when home_to_max is set soft_endstop.enable true # Enable soft endstops soft_endstop.x_min 1 # Minimum X position soft_endstop.x_max 300 # Maximum X position soft_endstop.y_min 1 # Minimum Y position soft_endstop.y_max 300 # Maximum Y position soft_endstop.z_min 1 # Minimum Z position soft_endstop.z_max 400 # Maximum Z position soft_endstop.halt false # Whether to issue a HALT state when hitting a soft endstop (if false, will just ignore commands that would exceed the limit) alpha_max_travel 300 # Max travel in mm for alpha/X axis when homing beta_max_travel 300 # Max travel in mm for beta/Y axis when homing gamma_max_travel 400 # Max travel in mm for gamma/Z axis when homing ### Optional enable limit switches, actions will stop if any enabled limit switch is triggered #alpha_limit_enable false # Set to true to enable X min and max limit switches #beta_limit_enable false # Set to true to enable Y min and max limit switches #gamma_limit_enable false # Set to true to enable Z min and max limit switches ### Endstops home at their fast feedrate first, then once the endstop is found they home again at their slow feedrate for accuracy alpha_fast_homing_rate_mm_s 50 # Alpha/X fast homing feedrate in mm/second alpha_slow_homing_rate_mm_s 25 # Alpha/X slow homing feedrate in mm/second beta_fast_homing_rate_mm_s 50 # Beta/Y fast homing feedrate in mm/second beta_slow_homing_rate_mm_s 25 # Beta/Y slow homing feedrate in mm/second gamma_fast_homing_rate_mm_s 4 # Gamma/Z fast homing feedrate in mm/second gamma_slow_homing_rate_mm_s 2 # Gamma/Z slow homing feedrate in mm/second alpha_homing_retract_mm 5 # Distance to retract from the endstop after it is hit for alpha/X beta_homing_retract_mm 5 # Distance to retract from the endstop after it is hit for beta/Y gamma_homing_retract_mm 1 # Distance to retract from the endstop after it is hit for gamma/Z
