Hi everybody.
I want to CONFIGURATION smoothie straight into flash of LPC without using SD card. Although I have copied the CONFIGURATION section in the memory card to Config.default, but when I remove the memory card, I cannot connect to the board.
I have Buildsell.cmd firmware main.bin and updated to LPC with memory card, but when reset and remove memory card. port is received but cannot connect to the board, I use openpnp.
Am I missing any more commands?
Yes, this is definitely not a PC, here every time such problems arise, kind of where there are even no tutorials.
Can you try using the default (un-modified) firmware, and try to boot without the sd card and see what happens ( as a test ) ?
do you have a UART cable to be able to see serial messages ?
