Communication problem between Chilipeppr and g2core (edge) 100.15 I upgraded my self compiled firmware
I upgraded my self compiled firmware to 100.15 but now i can’t connect with chilipeppr through the SPJS.
I am aware that only 1 Serial Port is exposed to the system.
But it is not possible to connect.
As someone suggested in another Thread here, i connected via a serial client (GTKTerm).
It works fine and i can communicate with the board.
Interestingly it seems i can connect to board when the serial client connection is open, but the board does not respond to commands (even not in CP console)
When i disconnect from serial client i am not able to connect chilipeppr through SPJS again.
Issuing a $ in serial console gives:
[fb] firmware build 100.15
[fbs] firmware build “100.15-5-g295d-dirty”
[fbc] firmware config “settings_default.h”
[fv] firmware version 0.99
[hp] hardware platform 3.00
[hv] hardware version 0.00
[id] g2core ID 0084-8ce7-0084-5ad
g2core[mm] ok>
Machine state: Stop
SPJS verbose log:
https://justpaste.it/11mfk
