I’m based in Bulgaria and am looking for a supplier for parts for a CO2 laser engraver. Any EU company should be ok. Does anybody have any recommendations?
I’ve also seen quite a bit of variance in price. What should I be looking for when purchasing the tube? My budget isn’t very high, but I need something that will be reliable! My machine is a 60W gweike Storm 600.
Hello,
I am based in Serbia and there are 2 main suppliers of lasers from China here (one of them got me my laser) and also there are representatives of Trotec and bigger companies available. I can send you a contact of the Chinese laser suppliers to see if they have or can get you the tubes you need if you want.
Yes please that would be great! I’ve spoken to a couple of suppliers from China including the manufacturers of my machine and they quoted me >$400 for delivery. Do you know companies with cheaper delivery options?
It’s definitely OK to provide useful links to commercial services here. Please do provide the links to suppliers who you have found, so that the next person looking for this information can find it easily.
We even allow commercial parties to provide those links themselves, as long as the substantial majority of what they post is not commercial (therefore, the they can’t post commercially until after they start participating in the community meaningfully) and they always disclose that they have a financial stake.
Here is the biggest supplier of CO2 lasers from China for Serbia. Here is their ad for tubes, and their email. Their site seems down at the moment but it will be on this link if it starts working at some time
I am not sure how they would do shipping to Bulgaria but probably that can be arranged since they ship to Macedonia.
Here is the other supplier with who you can check also. I bought my laser from the first company and so far I am satisfied, but it generally comes preassembled from China so that is what you get.
I think @mcdanlj is referring to the diameter of the tube. If you have access to a 3D printer, you can usually make some brackets if the new tube is not fitting the old ones.
Local suppliers are selling 60W tubes that are 100cm in length, but my current tube is 60W and 120cm. Do the different lengths here result in different power outputs? And if so is one referring to maximum power and the other to actual power rating?
I only need to use the tube at around 25% power so will a slightly shorter tube matter for my purposes if it’s still marketed as 60W?
I agree that all the 60W tubes I see for sale here in the US are around one meter long, regardless of diameter; I see a 1 meter long 50mm and 1080mm long 80mm diameter tube. I would expect you to be OK.
I know that my (1400mm) Reci tube was sold to me as a 100W tube but was tested to 114W.
Anyone else know anything particular here that I might be missing?
I have the tube installed and it was working, mirrors aligned etc. But now the laser cutting out intermittently. I managed to do a couple of test cuts and it was working ok, but now I can’t even get it to send a pulse.
Any recomendations of what to try? Could it be an electrical issue?
Start by pushing the test button down on the LPS.
If that fires the laser then the problem is usually other than the LPS.
Post a picture of the connector side of the LPS.
Is that on the control panel? I press the pulse button to fire the laser, and sometimes it fired a pulse and sometimes it doesn’t which I find quite strange
