I’m currently building a co2 laser for fibreglass fabric cutting. The initial setup will have a 80w laser, I may upgrade to 150w later if I can cut multiple sheets at the same time. Am I able to use a 150w power supply on the 80w laser tube so if I do upgrade the tube to 150w later the power supply is already capable of running it.
