CNC router: Spindle not turning on / intermittent
Hola amigos -
Booting up the CNC router, and when trying to activate the spindle (using g-code ‘m3 s1000’), (1) the spindle intermittently starts and stops - and I notice a small white spark from within the motor (2) it’s not turning on at all
See this video, where you can hear the motor audio:
(time: 5:30-6:30ish)
PS: First time using OBS to stream live to PeerTube / Makertube.net.
I have attempted: Re-connecting all spindle-related cables, power cycled the router & UGS.
Any ideas / suggestions? Planning to have a workshop tomorrow with some kids, where they will draw/design and we’ll etch it into wood.
// JRO
I think that is the end of the motor. It has the symptoms of both shorted and disconnected windings. When there are sparks on the brushes, it is often a sign that there are shorted windings and a motor not starting indicates that the brushes are connected to broken windings. Turn the motor a bit further or back and it starts again.
If you don’t want to disappoint the kids you might have to get yourself another router.
A while ago, someone mentioned something to the effect of “Ain’t nothing more useless than a broken CNC router” - and whatever the quote, I’ve been feeling it. Working on getting funding to replace the broken spindle, so I can get the router back into action.
I reached out to the manufacturer (Lunyee - which I would like to call out & appreciate for having excellent and responsive customer service!), and they asked me:
“what power spindle do you want to replace it with? We have 1.5kW and 2.2kW spindles.”
And I noticed that one is air cooled, and the other is water cooled. And the power is different than what I originally got. Can anyone share experiences, and suggestions?
Here are the product links they suggested:
This is the CNC router I have:
LUNYEE 4040 Turbo 3-axis linear guideway with 500W spindle for metal, wood, acrylic milling, Nema 23 motor working area 400 x 400 x 110mm
https://a.co/d/eN5tcgD
Thank you! :turkey:
Water-cooled is quieter, and the fan on an air-cooled spindle can rub things. I had my air-cooled spindle eat through my vacuum tube. Replaced it with water-cooled and am happy I did so.
What’s the water management & complexity side of things? The only water cooling I am familiar with is the chillers on CO2 lasers, and computer video/graphics cards. Hesitant about adding things that could leak or dramatically increase complexity / affect repairability.
Also - with the above spindles, with higher watts. Will that work with my existing power supply / controller?
You don’t need a chiller, just a radiator and pump. I bought a CW-3200 but the radiator eventually leaked, and in the end I replaced it with a radiator meant for a CPU/GPU cooler. @Eclsnowman mounted a radiator and pump on his gantry on his router.
Lasers have a much smaller range of acceptable water temperature. For a spindle, as long as the water isn’t boiling you are probably fine, as far as I know. :smiling_face:
Oh, they aren’t offering a matching power supply and controller as well?
Moving from brushed to brushless spindle means moving from DC power supply to a VFD providing variable-frequency three-phase AC. The VFD is supplied by mains power. It requires 3-wire power (plus ground) from the VFD to the spindle.
The two spindles use different collets; the 1.5kW uses ER16 and the 2.2kW uses ER20. Your 500W spindle might use ER11?
I am hoping to simply replace this spindle (either another unit of the original one, or a “drop in” replacement with a compatible / higher-quality one), and get it online.
I’m asking the manufacturer (Lunyee) how can I buy the replacement part and get this online.
Likewise - open to ideas you may have.
“Ain’t nothing more useless than a broken CNC router!”
This is the replacement spindle the manufacturer is recommending:
That’s cheaper than I expected! Recommend to go for it?
It’s probably fine for your use?
I have a similar spindle that ate the vacuum hose when it rubbed against it, but if you are trying to just replace like for like and the vendor tells you that’s the “like” variant, the only thing would be to compare to 500W 52mm brushed spindles from other vendors, and they are probably all pretty similar?
Going from a 500w 52mm to a 2.2kw 80mm spindle is a huge change. You didn’t say your machine but you are going from a hobby less than 1 hp motor to a commercial 2.5+ HP motor.
Think palm router to premium name brand plunge router.
Buy the inexpensive replacement until you are ready to upgrade the whole CNC.
