CNC Router - Dust collection hose suggestions
Hello!
I recently bought a dust shoe for my CNC router (as much as I love babysitting it with the vacuum wand…), and now I’m working to connect my vacuum to it.
I’ve found a few products online, but I’m curious to hear your suggestions.
Below are photos of the dimensions of the various parts.
Product I found online (aluminum hose with various attachments) - haven’t figured out if the dimensions will match my setup.
Think this would work? Other ideas?
Thank you for helping with my journey.
// Jonathan
The obvious question, sorry if this has been asked before.. do you have access to a 3d printer?
Hose adapters are very simple designs, easy to print, and easy to design yourself in openscad, freecad or whatever. Designs can also be found online.
I do have access to a 3D printer through public library & commercial / community organizations, but I don’t personally know how to use one.
I DO need a longer hose than what I have with the vacuum - it’s just at the point where if I pull it, the vacuum will fall over to its side. I would consider buying locally a longer length of hose, but still need to sort out the connectors.
I bought spiral hose and grounded it. What I bought is larger diameter than what you want because my vacuum is a dust collector. 2.5" PVC spiral hose.
You can always use the router to route out a bushing to mate a larger hose end.
Some observations on hoses:
  • straight is better than tapered or curved or a coupler — your ears will thank you for each place you can keep things from getting noisier or changing pitch by using a straight hose w/o complications
  • There are a few popular/common hose sizes, Imperial 1½, 2½, and 4″ — but this is complicated by inside vs. outside diameter — I’ve found it expedient to just buy both when there are a pair of options
  • PVC piping is available in similar diameters — but it doesn’t quite match, so some folks have adapters available
  • there are also clear acrylic tubes which are nice when they can be integrated so that one can see that stuff is moving — but if you cut metal they get scratched up and become cloudy quickly — but again, the diameters don’t quite match up (you’d think w/ just I.D., O.D., and wall-thickness it would be easier to make things which match up…) meaning even more adapters
I wrote a bit about making adapters at:
(ob. discl., I work for Carbide 3D, but we no longer sell the HDPE blocks…)
and the big thing is leave extra material on the first/roughing pass, test-fit/measure, and adjust for the finishing pass conservatively — once cut away the material can’t be put back…
Lastly, the finance committee will thank you in the long run for using a cyclone and saving on filters and expensive bags.
Possible source for hose and adapters
