Cnc hot wire cutter solutions?
not exactly cnc but… has anyone ever tried putting together an automated hot wire cutter?
I have a laser cutter and a cricut blade based cutter, but what I want to cut is 1" crafting foam, which is usually cut with a hot wire as it’s too thick for the above.
Any suggestions!
You can search this site for “hot wire” and find several. Here are some relatively recent posts from @freedom2000 on this topic, using Kiri:Moto:
Also see this cool thread on using GrblGru to cut out wings:
And this:
Yep foam cutting is a very cool adventure !
As mentionned by Michael, I made a full setup a few months ago. You can find how to use this at the end of this page : FluidNC 4 axis foam cutter controller | Details | Hackaday.io
And how to do it at the beginning !
Here is the finished product : “zenity” is mine and the orange one is the commercial ArtHobby
“Serenity” one !
Although very similar they are absolutely not the same !
Anything that’s just 2 axis?
I’m going to need to walk before I try to run.
foam cutters are 4 axis devices.
2 XY motions one on right side the other on left inside.
Sorry, I think that we’re talking at crossed purposes. When I say “2 Axis”, I mean a device that moves a cutting head in two dimension across a flat plan.
I’m thinking of something that resembles a hybrid between a Proxon desktop hot wire cutter and a desktop diode laser cutter, moving a head in height and width but not depth.
I’m not quite ready for anything else yet.
Ah ok I understand now !
It’s easy to do this with any CNC.
Here is my setup :slight_smile:
Replace the spindle by a vertical hotwire and move the bed only in XY plane.
You’ll have to support the foam stock to let the bottom wire arm slide under the foam…
