Hello everybody,
I have started work with diy soldering paste dispenser:
I have problem with 4th axis. Code is recompiled for 6 axis and cnc variant.
But motor on A axis doesn’t work…
So, motors configuration is below:
# A axis
delta_step_pin 2.3 # Pin for delta stepper step signal*
delta_dir_pin 0.22 # Pin for delta stepper direction*
delta_en_pin 0.21 # Pin for delta enable*
delta_current 0.5 # Z stepper motor current*
delta_max_rate 50000.0 # mm/min*
delta_acceleration 500.0 # mm/sec²*
epsilon_current 0.5 # Z stepper motor current*
epsilon_max_rate 50000.0 # mm/min*
epsilon_acceleration 500.0 # mm/sec²*
zeta_current 0.5 # Z stepper motor current*
zeta_max_rate 50000.0 # mm/min*
zeta_acceleration 500.0 # mm/sec²*
Si it correct ?
I tried to send G02/03 codes like :G2 X100 J5
but without success.
Do you have clues to go forward ?
Cheers
