Cloudray Air Assist Valve Issue – High airflow even when solenoid is off
Hi everyone,
I’m currently setting up the Cloudray Ultimate Air Assist kit on my CO2 laser, controlled via a relay module connected to the controller. However, I’m running into an issue with the air supply.
My Setup:
  • Solenoid Valve: 3/2-way valve labeled with ports P, A, and R.
  • Air Circuit: Splitter (T-fitting) before the valve for a dual-stage setup (low air for engraving via a manual flow control valve, high air for cutting via the solenoid).
  • Electrical: Relay module triggering the solenoid.
The Problem: Even when the solenoid valve is completely turned off (or disconnected electrically), there is still a high volume of air flowing directly to the laser head.
Connections:
  • Compressor $\rightarrow$ Splitter (T-fitting)
  • Solenoid Port P $\rightarrow$ Input from compressor
  • Solenoid Port A $\rightarrow$ Output to laser head
  • Solenoid Port R $\rightarrow$ Left open (Exhaust)
  • By-pass line: T-fitting to manual needle valve $\rightarrow$ merge to laser head line
Could this be a mechanical issue with the solenoid valve internal membrane/piston, incorrect port orientation, or am I missing something with the dual-stage T-fitting setup?
Any suggestions or help troubleshooting this would be greatly appreciated! Attached are photos of my pneumatic and relay wiring.
Thanks!
We don’t have math mode here. LLMs seem to assume that Discourse has math mode, so I’m assuming this was written with LLM assistance. Also, you didn’t actually attach pictures. Want to edit your post and attach the pictures?
I recently had a refrigerator go out and had to purchase a new one. So I took the water/ice maker control solenoid valve setup off of it before it went to the recyclers. I have plans to use those for my machine next year.
