Hi all, hope someone can help please! Had no reply from Cloudray themselves yet…
I currently have a Chinese laser cutter with an 80W Cloudray tube in it, and a Cloudray blue anodised head containing an 18mm lens.
I recently purchased a 20mm lens to make cutting easier; as it appeared from Cloudray’s Amazon and eBay listings like the head I have is compatible with 18 and 20mm lenses.
This seems NOT to be the case, unless I’m being stupid and missing something obvious… AM I being stupid and missing something obvious? LOL
If not, does anyone know where best to get hold of a 20mm head, please?
Thanks!
Screenshot of the head I have from Amazon.
Pics of the 18 and 20mm options are identical on there!
Those heads aren’t compatible with both lens sizes. You have to have the one make for a 20mm lens. If you have a 20mm head you could use a 18mm lens with a spacer but not the other way around.
If you have the K series head then this Amazon listing has an option for 20mm lens.
Cloud ray makes different styles of heads so if you could post a pic like Michael suggested we could confirm your setup.
