ChiliPeppr return to zero was used a lot in making this. I think it turned out great!
Very nice.
That looks great. Did you use a diamond bit for the etching? If so, do you mind sharing what kind?
Sure did, filled the etching area with water. Ended up having to cut a bit shorter to get the work piece under the Shapeoko. Really cheap, and surprisingly hold up well, as long as you have water or something cooling the bit. http://www.ebay.com/itm/20-Piece-Diamond-Burr-Bit-Grinder-Carving-Set-1-8-Shank-for-Rotary-Dremel-Tools-/400552988883?pt=LH_DefaultDomain_0&hash=item5d42d190d3
